steeve725
Mar 12, 2019Guide
Orbi remote management shows wrong model
Hi, Everyone Had my orbi system for a few days and really like it. Just dealing with what I think is another bug. Yesterday when I was away from home my remote management wasn't working. Wh...
Mar 13, 2019Guru - Experienced User
I would try the FW update...
steeve725 wrote:
New orbi app didn't make a difference. My router still shows as an rbr50 instead of rbr40 when off wifi and using remote management.
steeve725
Mar 13, 2019Guide
OK. So I guess that's another bug.
Because you obviously can't believe what the gui tells you when you check for updates. I checked for updates and it tells me my firmware is up to date @ 2.2.1.210
That's frustrating for the average person who believes what the router tells them when they check for updates and nothings found, because there still might be an update out there.
