Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the ...
OrbiPhilip
Jun 09, 2017Luminary
Same here for AC3000 running V1.10.1.2. I see speedtest and nothing else. Speed test works, but that's all that tab does.
I work from home and need to be able to prioritize my VOIP phone. It will not be recognized by the Orbi as RTP because the stream is inside a VPN tunnel. Even if it was recognized, I need to ensure that it has priority above all the other RTP devices that are streaming entertainment.
This was easy on the WRT54G running DD-WRT. I simply set the MAC of the VOIP device to highest priority.
- SKKDec 14, 2017Guide
When will Netgear officially support QOS on Orbi ? I have the exact same issue and get occasional disconnects on my main PC and ipphone and want to prioritize them.
- sdyarnellDec 30, 2017Guide
I also have this issue. I have 2 IP cameras that consistently stop working with the Orbi, but they keep their IP. I am trying to add some QoS prioritization to these cameras in hopes that it maybe makes a difference. With this page being basically blank, I cannot do this.
- Boomerang3Dec 30, 2017Apprentice
Your issue sounds like signal quality / strength?
