bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
DarrenM
Aug 03, 2017Sr. NETGEAR Moderator
If you could send me a private message with your name,email and phone number our support team can work with you on the drop connections you are having with the latest firmware.
DarrenM
mrtelarc
Nov 01, 2017Tutor
The problem in this discussion is exactly what I am experiencing - very easy to track as I have a Sonos system thoughout my house which drops out and requires a restart on the individual units. Signal is great and then drops drastically, not sure if it is "completely", but enough to cause numerous problems. Saw there was help and I really need it! Thanks! Bob
- st_shawNov 01, 2017Master
How is your Sonos system configured, Standard or Boost mode? How many of your Sonos devices are wired to your LAN?
- mrtelarcNov 01, 2017Tutor
No devices are wired to LAN - all are connected wirelessly to router, and with Netgear Nighthawk I had no problems with connectivy, but I did with coverage. Orbi is great until the signal drops periodically and then I lose connectivity (which stops Sonos from playing). I had a bridge system on it for several years which as a pain. Orbi is great if it wouldn't have disconects/drop of signal.
- TomZNov 01, 2017Tutor
I have an RBR50, RBS50; both with 2.0.74 firmware. I am experiencing WiFi dropouts as well, but it seems to be limited to my Galaxy Note 8. It won't stay connected for more than 10 minutes. This occurrs on my main SSID as well as the guest. I also changed the channels, and this had no effect.
Suggestions appreciated.
