bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
MrX911
Dec 07, 2017Apprentice
There has been new firmware released just a few days ago which for now seems to have cured my similar issues. Have you updated?
diggle
Thanx mrx911
just checked for updates via login......”No new Firmware Available”
i have V2.0.0.74
Funny actually....the router firmware has no update, and the satellite update said “No Internet”
so funny I’m about to cry
- MrX911Dec 07, 2017Apprentice
diggle wrote:Thanx mrx911
i have V2.0.0.74
It's not on the auto upate yet, its available manually. Let me find a link for you...
- mtlamDec 07, 2017Guide
Hey Diggle,
I believe the newest firmware isn't pushed out to update automatically. You're going have to do it manually.
i have V2.0.0.74
It's not om the auto upate yet, its avaialable manually. Let me find a link for you...
Here you go, try this. Mine has been much better
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/m-p/1448900#M16988
- diggleDec 07, 2017Apprentice
I just checked the Netgear support area...V2.0.0.74 is the latest zip to download.
Thnx....i’ll Give it a go
Thnx again MrX911
Ive updated router and satellite to V2.1.1.12
Youve given me new hope......I’ll let all know how it goes over the next day or so
- diggleDec 08, 2017Apprentice
Well.....it seems better....no dropouts all day......until I fired up an old ipad2 tonight and there it was again....router 0.0.0.0. Solved by resetting network details on ipad2 then restarting.
Im hoping it's a one off event.....
Checked this morning.....iPad Pro no longer connected to Internet despite Orbi device list and status saying no problem, old ipad2 remains connected. They were sitting next to each other on a coffee table overnight. This is with update of firmware yesterday to V2.1.1.12 of both Router and Satellite. The iPad Pro says "router 0.0.0.0" Orbilogin says all connected and no problems.
Very disappointing.
I'd like to think it was a problem with my clients....but clearly it isn't. I'd like to think Netgear hadn't caused the problem with the Orbi system, but it is obvious now that they did. I would also like to think that Netgear knows how to fix the problem, but clearly they don't.
Another session with netgear support will be my last.
I've been trying for an hour now to get my iPad Pro to connect to Internet through Orbi satellite, which is allowing access by the iPad I am typing on sitting next to it all the while.
Again...Orbilogin says everything fine and connected. It lists my iPad Pro as connected with no problems......but on the iPad Pro I'm getting :connected to Orbi network but "no internet connection" signal.
- diggleDec 09, 2017Apprentice
Just an update.
I have reconfigured every iPad/iPhone in the house to MANUALLY login to the wifi network. Dammit I shouldn’t have to do this, and will probably have to do this every time a new device appears in the house wanting to connect. Not so premium for a “premium” device which Orbi claims to be. So far all devices configured manually have remained connected.
I haven’t even looked at the laptops.......
- diggleDec 10, 2017Apprentice
I can't believe I'm still trying this. The MacBook was connected to Internet, but didn't appear on the list of connected items. After 30mins it stopped. Again recycled everything and got it going again for a while. I moved the satellite closer to the router, and it wouldn't connect. I moved it further away and it connected......I think that is just to do my head in. When I have any visitors, it's a lottery whether they can get a connection with their phones or iPads or laptops.
i need counselling. I rang netgear support again and was told after 45 mins that I would be put through to the "Orbi" department....then disconnected. Netgear should seriously examine their customer support. The firmware update V2.0.0.12 doesn't seem to make any difference.
apart. From returning the units I can't see any way forward. Does anyone have any further suggestions?
- BarryTregDec 10, 2017Apprentice
Hi, there's a couple of ideas at the end of this post that I started on my Orbi 'journey'...
I only have one old ipod on my network, no other apple products so not sure if it's any use or not.
- diggleDec 13, 2017Apprentice
Thanks for the suggestion Darren, I did see that manoeuvre in a very early post...but haven’t yet tried it...I think I’ve tried everything else, so I’ll give it a go. When I was speaking to Netgear support they didn’t mention this as an option...and some of their recommendations were the complete opposite of some of the forum recommendations...sadly none of which has been a decent fix for the problem.
There is of course the issue that none of this should be needed......the device worked perfectly for 7 months. Thanks again for the suggestion.
- maxscDec 13, 2017GuideThaks, tried that. Still same problems.
