Bandito
Dec 30, 2018Luminary
Orbi Satellite Slowdown
I continue to have problems with one Orbi satellite that after two-three days of use slows it's throughput dramatically. I can normally connect and get a full 300 Mpbs connection via the satellite, ...
Aug 20, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed on both RBR and RBS?
tannertanner wrote:The issue has occurred on all radio channels as one of my early troubleshooting steps was to try different channels. The affected devices are all connected on the 5ghz band. I do have a few devices connecting on the 2.4ghz band but I am less concerned about the speed of those and therefore haven't checked if they are affected in any way.
Currently I have the 5ghz channel set to 36 and the 2.4ghz channel set to 01. In the past I have set 2.4ghz to auto as well as 06 and 11. I have also tried the 5ghz channel 40. When the slowdown occurs I have double checked what the client and what the orbi router report and they both state that the device is connected via 5ghz. So although the speed decline would seem like it is connecting at 2.4ghz that doesn't appear to be the case.
I have one wired device. It is a mac mini. Running speed tests on that computer show that it is getting the full speed that my internet connection allows. I have also unplugged that device and it did not improve the problem for my wireless devices. The computer is set to use DHCP and so does not really have any custom configuration and is operating properly so I don't believe there is any configuration issue or hardware issue with it.
I am using Comcast cable internet for my ISP and the modem is a Motorola MB7621 DOCSIS 3.0. It is not set up as a router so I do not have a double router (nat) situation going.
The orbi is operating in Router mode. A simple restart of the Orbi fixes the issue for days and my wired device never experiences any slowdowns so there shouldn't be any issues with my cable modem.
tannertanner
Aug 20, 2019Aspirant
The house is 2100 sqft. My satelite is about 25 ft from the base unit. They are on different floors but it is a fairly straight line of site path down the stairs and the backhaul status says "Good". I get the same speeds when connected to the satellite or the base unit so I don't think there is any bottleneck there.
I definitely have wifi neighbors but I use a wifi analizer app to determine which channels are unpopulated and have my orbi set to use those. I have tried different channels but currently no other router is on the channel I have things set to on the 5ghz band and there are some very week signals on the 2.4ghz band. Restarting the orbi and leaving it on the same channel resolves the speed issue for days so this shouldn't be an interference issue. It also doesn't change once it starts going slow as once it is back to 40mbps it stays there until a restart. This isn't something that fluctuates. It is either running properly or it isn't. A reboot is the only cure.
I have tried many combinations of settings with no help but currently I do have MIMO and WMM turned on. I have never enabled Armor or Circle. I have tried with Daisy chain enabled and disabled but it currently is disabled. IPv6 is currently disabled. I don't see an option to set 20/40Mhz Coexistence to 40Mhz only. It is just a checkbox to enable or disable it. I guess I could disable it and see if it helps. I feel like I may have already done that but I could try to disable it.
I have performed a factory restore once shortly after purchasing the unit but that did not have any affect as after a few days the speeds went back down to 40mbps.
- FURRYe38Aug 20, 2019Guru - Experienced User
25 feet maybe a bit too close. Might try a bit farther out if possible. 30 feet is a good starting point.
When you uncheck the 20/40Mhz check box, this changed to 40Mhz only.
You might want to file a support ticket regarding this:
https://www.netgear.com/mynetgear/registration/login.aspx
tannertanner wrote:The house is 2100 sqft. My satelite is about 25 ft from the base unit. They are on different floors but it is a fairly straight line of site path down the stairs and the backhaul status says "Good". I get the same speeds when connected to the satellite or the base unit so I don't think there is any bottleneck there.
