GaryInEdmond
Dec 05, 2016Guide
Orbi satellite will not show connected devices
When I connect to my orbi satellite via 192.168.1.5, I get the normal home screen. When I click on connected devices, I get the "please wait a moment screen" and the devices never show. This starte...
- Jun 07, 2017
Hello tsutaz
Find the Ip address of those satellites in the attached devices then put that ip address into your web browser should be a 192.168.1.x address then you can see what is attached to that satellite.
DarrenM
Bing-Stroller
Jun 01, 2017Luminary
Thanks, tried that - made no difference.
tsutaz
Jun 03, 2017Guide
I just installed an additional satellite ( RBS50 ). Firmware shows v1.10.1.2. This is my 2nd satellite. It's installed upstairs and trying to fill so low coverage spots upstairs. I've rebooted an imac and a sony playstation upstairs. I can't tell if they are on the new satellite?
- DarrenMJun 07, 2017Sr. NETGEAR Moderator
Hello tsutaz
DarrenM
- tsutazJun 07, 2017GuideThanks Darren, Once I rebooted everything, the attached devices started showing up as expected. But I will try your idea as well.
