n19htmare
Jan 09, 2020Aspirant
Orbi satellites [RBS50] dropping connection
Dear Netgear. I have one Orbi router [RBR50] and 2 Orbi satellites [RBS50] in a Daisey chain. The backhaul status is always 'good' in the settings. Every few days the connection to satellites s...
Jan 17, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
n19htmare
Jan 17, 2020Aspirant
What is the distance between the router and satellite(s)? Answer: about 30 feet (backhaoul status is good in settings on 5Ghz after reboot).
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Answer: Tried all. Currenly back on auto.
Any Wifi Neighbors near by? If so, how many? Answer: Hardly any (a couple on channel 6).
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings Answer: Already enabled.
Try disabling the following and see: Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Answer: Cant diable Daisy Chain as needed to get good reception across the house. Others are disabled.
Has a factory reset and setup from scratch been performed since last FW update? Answer: Yes, including from the sotware then hard factory resetting each unit.
- FURRYe38Jan 17, 2020Guru - Experienced User
Ok, possible that your system or the RBS maybe faulty. Something I would open a support ticket and get more help from NG support. As about an RMA.
