ranzen
Dec 02, 2018Tutor
ORBI setzt die Glasfaser-Geschwindigkeit nicht um
Moin,
seit ca. einem Jahr wohne ich in einem Haus mit einem Telekom VDSL-Anschluß (100 MBit). Zur Verteilung des Internet-Anschlusses im ganzen Haus setze ich ein ORBI-System ein, bestehend aus...
ekhalil
Dec 15, 2018Master
ranzen wrote:
I found the mistake. The router RBR40 reduces the WAN speed from 1000M to 100M/full duplex after a few hours.
How can I turn this off?
This can also be another issue..
Do you have any switch in between the Router and Orbi? Have you tried changing the cable between the router and Orbi, it can also be a bad cable.
ranzen
Dec 15, 2018Tutor
No, there is no switch between the fiber router and the ORBI RBR40. The cable is a new CAT 6 cable (15m long).
- ekhalilDec 15, 2018Master
Ok, Do you have any wired devices connected to either the Router or Satellite?
Als, please try the other suggestions:
I understand that you have your Vodafone ISP router working providing router functionality and also wifi on.
This is not recommended and it will cause you many different random issues.
1. You have to switch of the wifi on the Vodafone router.
2. You then need to either set the ISP router in bridged mode or set the Orbi in AP Mode
Good luck
