slygato
Aug 26, 2016Aspirant
Orbi USB 2.0 port
The whole sales spew for Orbi is about throughput, throughput & even more throughput. Then they put a single USB 2.0 port on the thing? Here's some perspective: http://bestwirelessroutersnow.com/w...
- Aug 27, 2016
I hadn't considered that. It crossed my mind that it would be cool if I could use one of the 1gb Ethernet ports for a storage connection, but I haven't spent any time at all looking into this (obviously.) I'll look into what's available and put a temporary moratorium on my carping about the USB 2.0.
My other concern was regarding the RF radiation from these puppies and from what I've been able to determine, these things will be putting out about 36dbm (about 1 1/2 Watts) and that a person five feet from the the unit will be irradiated with a -30dbm signal, which is 60dbm down. I'm not an engineer but -60dbm is a million times less (at least it is on the farm where I was raised.) From the experts at Drudgereport.com and other authorities, 5Ghz is non-ionizing radiation which is far safer than ionizing radiation. The point being, maybe I'll put aside my concerns about USB 2.0 and RF radiation and not cancel the order. At least these are things to think about during the next two weeks.
mdgm-ntgr
Aug 27, 2016NETGEAR Employee Retired
The key feature of Orbi is the whole home Wi-Fi and that's what our focus has been on.
USB3 is great, but working with a USB disk does use up resources that the router could use for something else.
If you want to use USB3 you could connect a Nighthawk via Ethernet to the Orbi router and connect the USB disk to that. One of the two routers should be in Access Point (AP) mode to avoid double NAT.
Or better yet you could connect a NAS such as our ReadyNAS via Ethernet. The NAS has a number of backup options and with multiple disk bays a redundant RAID level could be used to provide some protection against a disk failure.
slygato
Aug 27, 2016Aspirant
