Lorvau
Sep 24, 2020Guide
Orbi Voice using Alexa timer/alarm doesn't go off
I have been using my Orbi Voice Satellite Alexa feature. It has been great. Two days ago, I noticed the Alexa ability using a timer (or an alarm) no longer works (it doesn't ring or flash). Alexa ...
Soke577
May 21, 2021Initiate
I have the same problem how I can fix?
Blanca_O
May 27, 2021NETGEAR Employee Retired
Hi, All,
If you're experiencing issue using Alexa Timer with the Orbi Voice Satellite, please send me a private message with your name, email address and device serial number as we may have a beta version that may help address the issue(s).
Blanca
Community Team
- intellerJun 13, 2021Apprentice
It shouldnt be a beta firmware. It should be a patch for what you broke in this firmware. Development process is broken here.
- gg7aphSep 13, 2021Tutor
Hello Blanca
I'm interested in trying the beta firmare that may resolve the lack of timer issue on Orbi Voice. My detials are below:
name: ANDREW HARGREAVES
email address: [email protected]
device serial number: 5F928A7GA108D
Thanks
- obisbo99Sep 22, 2021AspirantSo the new firmware says it fixes the alarm issue which it technically does but now I cannot turn off the alarm. It keeps going off no matter what I say to Alexa. The only way to stop the alarm is to delete it in the app.
- LorvauSep 22, 2021GuideOriginally to stop it, I would say “Alexa Stop” but now with the patch, I have to say “Alexa Stop Timer” or “Alexa Stop Alarm”. Netgear does not consider this to be their problem. Annoying but it works.
- davidh348Sep 25, 2021Aspirant
The device used to give me a verbal announcement reminder but now only sends me a message to my apple phone.
Do you have a fix?
