stevelk9999
Jul 17, 2019Tutor
ORBI VPN and Armour
I enabled VPN on my router and set up the Mynear DDNS. This seemed simple, I then downloaded the OPen VPN app onto my android I then downloaded the open vpn configuration and transferred...
Jul 17, 2019Guru - Experienced User
I would post about this over on the Armor forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
stevelk9999
Jul 17, 2019Tutor
Thank you for your help. I posted there as well. It seems that I when I turn off wifi and use cellular I can connect. I just wanted to check before I installed the laptop/windows version
- FURRYe38Jul 17, 2019Guru - Experienced User
Disable Armor as well and test.
- stevelk9999Jul 17, 2019Tutor
Thanks. I was hesitating to mess with it while it worked.
So for the record,
1. Whether or not armor is enabled, I can connect via cell network
2. Whether or not armor is enabled, I cannot connect internally with WIFI though it doesnt matter since I can connect without VPN.
For the record I took out the Bitfender box 2 since I wanted to add VPN
I know a lot of people have asked about Bitdefender box 2 versus Armor but I cant really say. I havent noticed any speed issues or problems with either.
thanks again
- stevelk9999Jul 18, 2019Tutor
1. Thanks to this board, I have set up my orbi and open VPN at House A and it seems to be working well. I live here during the week for a temporary job.
2. I will now like to set this up at house B with another Orbi ( loyal netgear customer)
My question is I would like to use the same laptop that I take back and forth and want to know how to set up a second NETGEAR Tap adapter?
