AmitR
Jan 04, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 17, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
lowepg
Jan 13, 2018Apprentice
What are the major differences with the Pro?
im interested. I have to admit though- part of me hates the idea of rewarding Netgear with more business because the standard orbis are such a cluster-&&*&^&*
setham
Jan 13, 2018Star
lowepg wrote:What are the major differences with the Pro?
+$250 for the 3-pack :smileylol:
- lowepgJan 13, 2018Apprentice
Yeah... I know more expensive.
But are the radios the same? Same coverage? Speed?
In other words- is all we’re getting for the price increase a working version of the same old orbi?
- wase4711Jan 13, 2018Luminary
3 wifi networks
many more admin functions
works perfectly in either router mode or AP mode
obviously, better firmware, since it works without issue
looks a little different
range seems better, but might be placebo
no bugs or issues..
