AmitR
Feb 13, 2018NETGEAR Employee Retired
OrbiOS MR 2.1 issues
I wanted to reach out to provide a quick update on OrbiOS 2.1 software. We believe that these issues are affecting some users. Rest assured that we've been following this issue and working hard beh...
JCinNC
Feb 18, 2018Guide
Can you put the router on the middle floor and then a satellite above and a satellite below? Our lake house is 3 stories and that is what I did there to avoid wired backhaul.
Since you have it wired, come out of your modem, etc and use the ethernet to go to the middle floor location and place the ORBi router there plugging the ethernet into the yellow WAN port. Then bring the two satellites in the same room and make sure they connect wirelessly. Once that is done take them to floor 3 and floor 1 and verify connection in the connected devices screen on the router. Should work fine.
JC
johnysnydz
Feb 18, 2018Tutor
Ugh... i respect your suggestion and would have to seriously get to my wits end for that. lol... You are correct in that i COULD do that with my wiring config. I spent over a grand pre wiring my house for ethernet and that would be scrapping all of that.
- JCinNCFeb 18, 2018Guide
Not scrapping, just patching
Once they fix the issues and backhaul becomes available you can restore your configuration. Unfortunately I can tell you that you will get to your wits end with this. I have been chasing it for a couple of months and I owned a solutions intergration company for 20 years and chose this solution so that I wouldn't have to deal with fixing wireless issues at home when they occurred. Our commercial Ubiquiti systems never had these issues but I was the only one in the home that could address the issue.
It's not ideal but it will save you hours of frustration.
GOOD LUCK
JC
- johnysnydzFeb 18, 2018Tutor
I just realized this wouldnt work for me as I am running a POE VOIP phone system so i need the ethernet lines. This sucks. I have been an SMB IT guy my entire life and chose this system as i thought it would give me bulletproof wifi in my house.
