AmitR
Feb 13, 2018NETGEAR Employee Retired
OrbiOS MR 2.1 issues
I wanted to reach out to provide a quick update on OrbiOS 2.1 software. We believe that these issues are affecting some users. Rest assured that we've been following this issue and working hard beh...
Origosis
Feb 26, 2018Guide
This is exactly how I feel about Netgear and the Orbi. I have owned mine for 16 months. And it has never gone more than a weel without some kind of problem. And when it does have problems it will have them multiple times a day.
The newest fix of going down the 2.0 from 2.1 and factory resettin everything has lead to about 2 weeks of solid perfoamnce.
But for $400 and 16 months of one of the worst consumer products I have ever owned. I also feel like Netgear owes me for beta testin this piece of crap.
Supertramp11
Mar 02, 2018Luminary
Please speak with your ReadyNAS colleagues about what a possible solution can be for stopping auto updates of the FW. Auto checking for new FW is ok when accessing the admin client, but then the final choice to upgrade - or not - lies with the admin.
- acrawford72Mar 02, 2018Guide
Firmware has not auto updated. is still at 2.0.1.4
- lbdyckMar 02, 2018Star
after downgrading to 2.0.1.4 it has not auto-updated but there are still issues and a new one this morning.
I used the iPhone IOS Orbi app and did a speed test which resulted n the unit rebooting itself.
ARG ! ! !
- caremd99Mar 02, 2018AspirantI am on 2.1.2.18 and had the same happen last night. Too bad because it had been running nonstop for more than 14 days. I run in AP mode.
- FURRYe38Mar 02, 2018Guru - Experienced User
Try disabling MIMO and Daisy Chain and test againg to see if router reboots when doing a speed test. Disable Beamforming as well. Re-enable them after testing if results are the same.
Whats the Mfr and model# of the ISP modem? Any built in router by chance?
lbdyckwrote:after downgrading to 2.0.1.4 it has not auto-updated but there are still issues and a new one this morning.
ARG ! ! !
FURRYe38 - the modem is from AT&T uVerse and is locked in a closet. I'm off on a business trip in a few minutes so will have to wait until I return to do the tests and get the details on the modem. The Orbi is using factory defaults for nearly everything except the ssid and passwords. no guest network. only 1 wired connection to the orbi.
Is the ATT modems wifi enabled? I know that Uvserse modems can't be bridged. You can use the modems DMZ for the IP address that the Orbi router gets from the modem. This will help get better internet thru the modem to the router. I would ensure the modems WiFi is disabled fullly as well.
Have a good trip. Let us know how it goes when you return.
lbdyckwrote:FURRYe38 - the modem is from AT&T uVerse and is locked in a closet. I'm off on a business trip in a few minutes so will have to wait until I return to do the tests and get the details on the modem. The Orbi is using factory defaults for nearly everything except the ssid and passwords. no guest network. only 1 wired connection to the orbi.
AT&T modem has wifi disabled
- wildhorseMar 02, 2018Star
I have done countless speed tests using both laptop and android mobile phone and it never resulted in reboot. If you keep getting reboots even with 2.0.x firmware and factory settings then most likely you've got a hardware fault.
