Iketurner10
Jan 22, 2019Tutor
Philips Hue issue
Hi All,
Can somebody shed some light on why I can’t get Philips Hue to find a new device (light) please.
My setup is as follows:
1 x TalkTalk router
1 x RBR50 router and satellit...
- Jan 22, 2019Zigbee runs over 2.4Ghz. Zigbee and Wi-Fi are not supposed to interfere with each other but in my experience I have seen it happen. Move your bridge away from your router and make sure your lights aren’t near any other wifi or Bluetooth devices.
st_shaw
Jan 22, 2019Master
It's not clear to me exactly what you're doing, but I find it common for my Hue sytems to be unable to find lights. That's also the case without Orbi. What helps is to enter the light's serial number on the search screen before searching for the new light.
- eljarvisoJan 22, 2019LuminaryZigbee runs over 2.4Ghz. Zigbee and Wi-Fi are not supposed to interfere with each other but in my experience I have seen it happen. Move your bridge away from your router and make sure your lights aren’t near any other wifi or Bluetooth devices.
- Iketurner10Jan 23, 2019Tutor
Hi guys,
Thanks for your help on the matter it seems the Hue bridge was too far away from the device. Moved it closer and voila - all works well.
Cheers
- FURRYe38Jan 23, 2019Guru - Experienced User
Glad you got it working. Mark your thread resolved so others will now.
Iketurner10 wrote:
Hi guys,
Cheers
Enjoy. :smileywink:
