beckss1
Dec 14, 2018Tutor
Problem with wired connection RBR40.
Dear community.
I worked with my ORBI (RBR40) for 5 months and today I connect (wired) to router IX220 (LenovoEMC Storage). Two things happened, that I would like ask gurus:
1. After connection I...
beckss1
Dec 17, 2018Tutor
Thanks for guys for replying.
I will check and read how to change Orbi to AP mode and will check you solutions.
Thanks and regards.
Thanks and regards.
beckss1
Dec 17, 2018Tutor
By the way ISP modem is "Dual band wireless N600 VDSL modem router"
- FURRYe38Dec 17, 2018Guru - Experienced User
Be sure to try one of the following for your ISP modem:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thanks for letting us know about the modem.
beckss1 wrote:
By the way ISP modem is "Dual band wireless N600 VDSL modem router"- beckss1Dec 17, 2018TutorHi.
Sorry for my stupid question. If I will change Orbi from router to AP mode I need make something additional configuration or just change into advance section and all definitions, that were saved on router , will be worked.
Thanks.- ekhalilDec 17, 2018Master
beckss1 wrote:
Hi.
Thanks.Yes, basically all basic settings will stay the same. Only router related functionality, like DHCP, VPN, DDNS, .. will cease to work from Orbi and you should get equivalent functionality from your ISP router instead.
