beckss1
Dec 14, 2018Tutor
Problem with wired connection RBR40.
Dear community.
I worked with my ORBI (RBR40) for 5 months and today I connect (wired) to router IX220 (LenovoEMC Storage). Two things happened, that I would like ask gurus:
1. After connection I...
Dec 17, 2018Guru - Experienced User
Well at least the WAN and LAN ports are Gb supporting and not 100Mb.
- Five (5) 10/100/1000 (1 WAN and 4 LAN) Gigabit Ethernet ports
https://www.netgear.com/home/products/networking/dsl-modems-routers/dgnd3700.aspx#tab-techspecs
So if they can bridge the modem, it should be ok for there needs.
beckss1
Dec 18, 2018Tutor
Thank to all guys, that replying to my problem.
Will check possibility purchasing new one.
Thanks and regards
Thanks and regards
- FURRYe38Dec 18, 2018Guru - Experienced User
Try to find a modem only unit with out a built in router. You don't need a built in router if your going to use a external router like the Orbi.
Thanks and regards
