paulb73
Jan 29, 2019Initiate
PS4 Refusing to connect to Orbi WiFi
Hi Folks
For some reason my PS4 is refusing to connect to my Orbi WiFi network. It has previously worked fine (though I haven’t used it in a while). When I go through the network configuration ...
- Jan 29, 2019
It's not you! It's the newer FW. My PS4 dropped every 2-5 minutes. Had to go back to ethernet.
Don't waste your time breaking yout PS4.
Instead. Roll back your Orbi FW and the problem will likely resolve itself.
Flash008
Jan 29, 2019Luminary
