comrade
Aug 27, 2019Aspirant
RB50 - Nas over Wirless Backhaul
Hey Folks, I have an RBR50 connected next to a Virgin Media modem, a RBS50 Upstairs thats connected Wired into my PC with a 1GB lan port. Now when I transfer from my hard drive on my PC to my NA...
Aug 27, 2019Guru - Experienced User
Beamforming and MIMO effect only wireless connections.
Wireless speeds will not be the same as wired speeds as well.
comrade
I know that, but this is to do with the backhaul. MIMO and Beamforming wont affect the backhaul. My question is regarding the throughput and the overhead. When I SSHed into the router it said the ling speed was 1300mb which is the max speed for the wireless backhaul. Just seems pretty bad really that from a theoretical max of >160Mb/s I lose about that much
- FURRYe38Aug 27, 2019Guru - Experienced User
The 1300Mbps you see is the connection rate between the RBR and RBS only. This is not a actual thruput speed for traffic. Different animal.
