RGOLD
Feb 28, 2019Tutor
RBK20/22 Owners - Do not upgrade to V2.3.0.28
Firmware V2.3.0.28 has issue with connecting devices to sattelite. All devices will stay connected to the router. Had to revert back to firmware V2.2.1.210.
- Mar 01, 2019
UPDATE:
Moving the 2.4GHZ from busy channel 1 to channel 11 resolved the issue, now I have half of my 18 devices connecting via the satellite as it use to before. I never bother to do a factory reset but if I did in this case, it will probably auto chose the less busy channel and the problem will also be solved.
Mar 02, 2019Guru - Experienced User
Sounds like you found the problem. Yes busy surroudings can cause problems. Why manual channel selection is good as well.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Glad it's not the FW.
Enjoy. :smileywink:
RGOLD wrote:
UPDATE:
Bullyterrier
Mar 03, 2019Star
Just to say my 43 when manually updated to this firmware had a number of settings reset. Firstly for WIFI my previous manually set 2.4 channel was reset to auto and secondly fast roaming was reset to off. Daisy chain was also reset to on.
This choice (undocumented) to reset certain saved parameters will no doubt causes a number of these type of issues across the less tech savvy part of the installed base.
- FURRYe38Mar 03, 2019Guru - Experienced User
I would do a factory reset on the entire system after the update. Setup from scratch. After it's all set up, do a save config to file under Advanced Tab/Advanced Settings/Backup. Keep this save config file for future use.
