icemagic17
Mar 05, 2019Tutor
RBK40 Orbi connectivity issues
I have an ORBI RB40 I purchased last year. It has been great, but in the last month I am having connectivity issues. When I return home or restart a device, I need to turn off the wifi on the devic...
- Mar 06, 2019
Ok, have her disable the wifi on the phone for about 10 seconds then back on, and also "forget this network" on the phone and then attempt to re-join.
Keep us posted.
icemagic17 wrote:
I did those adjustments last night and had most devices connected. My wife said her phone didn’t connect in the morning before she left for work. I will check everything again tonight.
Mar 05, 2019Guru - Experienced User
icemagic17 wrote:
Sorry amature hour here. By FW is that the version? It is 2.2.1.210 YES
Technicolor TC8305C <This is a router and wifi modem combo:
https://www.router-reset.com/reset-manuals/Technicolor/TC8305C
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I believe the ORBI is in router mode, but am not sure how to double check and verify. Navigate to Advanced Tab/Advanced Settings\Router and AP mode.
The house is about 3500 sq ft.
The satelites are within 20 ft of the main ORBI. Almost directly above and below on separate floors. 20 feet is too close between the base router and satellites. 30 feet is recommended in between them to begin with depending upon building materials.
I tried resetting the 5 ghz channel to 40 because no one else appeared to be using that one. That didn't help at all.
I live in a standard neighborhood and when I pull up networks I would guess I can find over 10, some being from the same house as they are labeled guest network.
Security is WPA2-PSK
How do you enable MIMO and beanforming?
Navigate to Advanced Tab/Advanced Settings\Wireless Settings
icemagic17
Mar 05, 2019Tutor
Thank you. I had to head into work, but I will try these things when I get home tonight.
- FURRYe38Mar 06, 2019Guru - Experienced User
Hope the suggestions help. Let us know how it goes...
- icemagic17Mar 06, 2019TutorI did those adjustments last night and had most devices connected. My wife said her phone didn’t connect in the morning before she left for work. I will check everything again tonight.
Keep us posted.
