rsquarev1
Feb 26, 2019Tutor
RBK40 v2.2.1.210 Satellite drops internet
My RBK40 was setup more than a month ago and it was updated to latest firmware by that time to 2.2.1.210. Then I had to factory reset my router twice to work properly. Issue is that devicess connecte...
- Apr 08, 2019
Netgear support replaced the satellite with other one. New satellite didnt work plug and play. Had to reconfigure both router and satellite together. But finally it works.
Mar 11, 2019Guru - Experienced User
See how the satellite does at 30 feet.
When you has the satellite at the remote location ethernet connected, was daisy chain disabled?
You can try the satellite close before moving with the ethernet connection again to see if the satellite fails before moving it. Try swaping LAN cables as well. Use good qualilty LAN cables. CAT6 is recommended.
rsquarev1 wrote:
Netgear support was no good. I was never received call from next level support person, though I was promised I get call within 24 hours. Now it is 10days.
While waiting for the support call, I have factory reset my router and satellite (after 2.3.0.28). Configured and imported my settings again. This time I placed my satellite around 10ft (radial) distance without ethernet, though the spot is not ideal for me. So far it is 10days and I haven't had any problems. This week I will test satellite by placing where I would like to. And I update what I find in one week.
AlmondRoca wrote:
If you could keep us updated. Thanks!
rsquarev1
Mar 13, 2019Tutor
Its been two days, I moved my satellite more than 20 feet away from router and wired. So far it is great, no issues or instability.
Satellite CPU is now between 13 & 20%. It was over 45 constantly in the past.
Router CPU is pretty stable at 8-15%
I am not sure what made it stable now. I suspect the firmware update is not clean. Noticed this everytime I updated firmware (3 versions I did). And many in netgear community suggested to do this. Though it doesnt work all the time, I guess you need to keep doing this until it works. For sure, this is not the quality we are expecting from Netgear.
Series of things I did in given sequence below are...
- Backup settings
- Factory reset on router & satellite
- Firmware update to 2.3.0.28 manually on router & satellite
- Reconfigure router using setup wizard
- Firmware update to 2.3.0.28 manually on router & satellite (yes, I did same update twice)
- Import settings that are previously backed up
I will watch next few days and update here if I notice any problems. Thank you all for the help. Great community!!
