Ha_Ku_Na's avatar
Ha_Ku_Na
Luminary
May 31, 2018
RBK50 / 3x RBS50 -> download slowed down since a few days, upload not affected
Hi I experience an issue with the download performance since a few days. My system: 1x RBK50 connected to provider router (router mode, I know doublöe NAT, but I want to ise the DNS of the OR...
  • Ha_Ku_Na's avatar
    Ha_Ku_Na
    Jun 06, 2018
    Hi
    I installed the new fw in the meantime and made further testing.
    The issue seems to be either isp or router (from isp) related.
    I tested with a wired laptop directly on the isp router and experienced the same effects.
    The provider will no deliver a replacement router. Therefore I guess I can close this issue.
    thx for some helpul hints.
