y_g
Sep 15, 2017Aspirant
RBK50 5Ghz Network capped at 400M
Hello. I have just received my RBK50 set it up and updated to latest firmware (2.0.0.72) and and both old and new versions 5Ghz network show that it's working in 400Mbps mode(see sceenshot). I ...
- Sep 17, 2017
Ok, I did a factory reset and set it up again and now everything is fine. If anyone encounters similar problem, hope this helps.
st_shaw
Sep 15, 2017Master
I looks like it's only 400 Mbps because the Orbi is using only 40 MHz bandwidth on 5 GHz instead of 80 MHz. Yours shows 2 channels (36+40). Mine shows four (36+40+44+48).
Maybe this is a local regulation where you are, or maybe the router sees interference and is falling back to 40 MHz?
You could try changing the 5 GHz channel and see if that changes anything.
y_g
Tried changing both regions and channels, they change, but still only 2 simultaneous bands (interestingly there are 8 total channels to choose from 36,40,44,48, 149, 153, 157, 161) and choosing higher channels actually changes to some other values up to 60 after rebooting
- st_shawSep 15, 2017Master
Interesting. Here in the US, my only channel option are 36, 40, 44, 48. I'm not sure changing the settings has any effect either, since they are all part of one 80 MHz channel.
