Threftlet
Sep 29, 2023Guide
RBK50 firmware update search fails
When I try to use the Netgear iOS app to find firmware updates for my Orbi, I only get a message that searching for updates failed. Is there any workaround for that?
- Sep 29, 2023
I performed the reset again and this time it worked. I must have interrupted it the first time by bouncing the units. Anyway, the firmware appears to show the correct version for all devices now, but my remaining question is how can I get rid of "Config Sync" in Attached Devices and replace it with "Good"? I'll eventually learn to love my Orbi again, but honestly, this was too severe a test.
Threftlet
Sep 29, 2023Guide
CrimpOn
Sep 29, 2023Guru - Experienced User
I have had satellites display "Config Sync" for quite some time, and then..... become "Good".
If you can demonstrate that that the satellites are actually functioning correctly, i.e. devices connected to the satellites have internet, then perhaps "Ignorance is bliss"?
