TLane1957
Jan 08, 2019Tutor
RBK50 how do I change my IP Address
My IP address on my router is 10.0.0.1 and I need to change it to a 198.168.0.1 IP address. How can I do this?
Thanks,
Tony
michaelkenward
Jan 09, 2019Guru - Experienced User
It wasn't just the LAN ports. I try to pin down these things by checking manuals. Sadly, this doesn't always work. Google can lead you astray. Yesterday, I had some difficulty trying to work out what a Huawei box was all about.
I did link to the manual I found. If they have instructions for "routering" it suggests that they think it necessary and it makes sense to follow them.
Did you look at that?
But a different search for the same thing found something with a single LAN port.
st_shaw
Jan 09, 2019Master
I dug a bit more and am now confident the multiple LAN ports are for bonded connections. The Quick Reference Guide is below, describes removing the yellow tape in the unlikely event you are using a bonded connection, and reads, "This product does not include a router...."
The OP should simply adjust his LAN IP range as I described in my first post.
