the5rivers
Mar 06, 2020Tutor
RBK53 AP Mode Not Working with TDS Fiber Modem
Hello everyone. I have searched through the forum and on the web and cannot find info specific to my situation. I have fiber through TDS, they have provided a Calix 716ge modem (ONT), and my RBK53 ro...
Mar 06, 2020Guru - Experienced User
You need to ask your ISP what is needed so that you can interface the Orbi's RBR to there services. There needs to be some form of Ethernet interface connection at the ONT or some router or modem that the RBR can connect to for its' WAN port connection.
The Actiontec is a gateway modem, which can be used however already has a built in router and wifi.
https://www.windstream.com/support/internet/wi-fi-network/Actiontec-T3200
the5rivers
Mar 06, 2020Tutor
Yeah they said no modem is necessary with a fiber connection. They are taking the fiber line and terminating it at the ONT, then using an ethernet wire from the LAN 1 port to my RBR50. Everything works as adverstised via a wireless backhaul. I just cant get the RBR50 to work in AP mode.
I suspect I will have to ask for an actiontec or whatever modem they use, and have them disable the router/wifi capabilities in order for this to work. Would that be a correct assumption?
Thanks for your help.
- FURRYe38Mar 06, 2020Guru - Experienced User
Ya you'll need another router inbetween if you want to use the Orbi in AP mode.
- Retired_MemberMar 06, 2020
From what I understand, the Orbi needs a modem (like most routers).
AP mode = 2 routers involved.
Not clear on what you're trying to accomplish by seeking the AP mode.
Good luck
- the5riversMar 06, 2020Tutor
I want to utilize the ethernet wiring within my house, and leverage a wired etherent backhaul with my RBR setup instead of wireless.
the5rivers wrote:I want to utilize the ethernet wiring within my house, and leverage a wired etherent backhaul with my RBR setup instead of wireless.
ok...good luck.
As suggested in an earlier post, you may want to discuss this with your ISP ask them if you can do what you're trying to do?
ISP entry point into a home appears to be where the main question begins.
