JulesWilko
Mar 26, 2018Tutor
RBK53 vs RBK43 backhaul range
Heya there folks, Does anyone know if the range of the backhaul is significantly different between the RBK53 and RBK43? I'm not too bothered about speed as the internet connectivity is only 10mb...
Mar 27, 2018Guru - Experienced User
Give the 50 a try and let us know if this works for you...
AmitR
Mar 27, 2018NETGEAR Employee Retired
If you have a challenging RF environment (e.g. exterior walls, lots of walls, etc), the 4x4 backhaul on the 50 series will do better than the 2x2 radios. In short, more radios & antennas will either translate into longer reach at same speed or faster speed at same distance.
