wchp
Nov 11, 2019Luminary
RBK53 vs RBK53S Vs RBK53S-100NAS
So on a previous thread a Netgear moderator responds to a question on the difference between the RBK53 vs RBK53S by stating the S version adds 1yr of Armor firewall but deletes the USB port. Costco s...
tagteam
Nov 11, 2019Virtuoso
wchp wrote:The question I have is there actualy such a model (Costco specific) and does it support "ReadyShare"?
I guess we'll find out but I'll be shocked if (a) it has a USB port and (b) it supports ReadyShare. Judging by what appears to be the same system from Amazon, it sure doesn't seem as if either is the case. As a side note, it really looks like Netgear has thrown in the towel on ReadyShare for the Orbi since even the new WiFi 6 model (RBR850 or whatever) doesn't support it.
wchp
Honestly I will surprised too. Oddly New Egg list the -100NAS model and lists a USB port in the specifications as well.
- wchpNov 13, 2019Luminary
The RBK53S-100NAS does NOT have a USB port and therefor no way to support ReadyShare.
Picked up the "new" model from Costco today and the are no USB ports to be found.
- tagteamNov 13, 2019Virtuoso
wchp wrote:The RBK53S-100NAS does NOT have a USB port and therefor no way to support ReadyShare.
Thanks for confirming that. Obviously, the "NAS" at the end of the product number is a bit misleading, but, whatever.
So, it appears that unless you can find a reseller that is selling older systems, you're going to get the "v2" router and satellite(s).
