krishdhar
Apr 11, 2021Tutor
RBR20 latest firmware update V2.6.2.104
I just updated the firmware on RBR20 to V2.6.2.104 and now I have some devices have internet and others don't. Don't know why some devices cannot get internet even though they connect to wifi and I c...
Apr 15, 2021Guru - Experienced User
Ha_Ku_Na Just curious, when you activated TM, how did you configure it? I set mine for No Limit and just reporing data flow. Haven't seen any issues. Though I'm using the beta now. :smileyembarrassed:
Ha_Ku_Na
Apr 15, 2021Luminary
FURRYe38 wrote:Ha_Ku_Na Just curious, when you activated TM, how did you configure it? I set mine for No Limit and just reporing data flow. Haven't seen any issues. Though I'm using the beta now. :smileyembarrassed:
As I remember, I just enabled it without set any limits and not restartet the RBR/S's.
On the next morning, a lot of the connected devices were no longer working as expected.
Afterwards I've done a factory reset and reloaded the config from file.
Btw, I also asked a week ago one of the moderators for the beta but got no response until now ... any chance you can provide the files for RBR/S 50 ?
- FURRYe38Apr 15, 2021Guru - Experienced User
Ok, I set No Limit on the RBR, applied the setting and rebooted the RBR or I may have powered if OFF for 15 seconds then back ON. Did not see any problems with any devices after that.
Also did not load a saved configuration from file either.
