Asdirect's avatar
Aug 09, 2017
RBR40 Firmware V1.12.0.20
I'm afraid to update my firmware to v1.12.0.20............   Has anyone done this? Are there any known issues? Does it appear stable?
  • YabbadabbaDoooo's avatar
    YabbadabbaDoooo
    Aug 10, 2017
    Ah if it were only that simple. It will sit there for a week or more but eventually it will auto update. You can't stop it. If I were in your shoes I would return it. Several months ago after 2 months of this same crap, I was able to convince Amazon to take it back for a full refund even though it was a month out of the return time. I had the label printed but 1.11.0.20 had just come out. I went out of town for 2 days and when I came back my system was stable and running the way it was always supposed to. I waited a few more days and then cancelled the return. Big mistake. Should have listened to my instincts.
