BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Apr 03, 2021Guru - Experienced User
Try a factory reset and setup from scratch next time. Not seeing any wifi isuses here with v104 loaded.
Gebla wrote:Wifi still very slow, I will move back to a previous release. Second time after a firmware update I need to refer back to a previous release. Thank you Netgear for your excellent work
Gebla
Apr 03, 2021Apprentice
Moved back to 2.5.1.16 this is the only reliable firmware for me.
Considering the price of the system I should not do all this work and or do factory reset.
Factory reset means I will have to set all port forwarding again and several iot devices in the network must be reconfigured again
In this case firmware update caused reset of the router so it means that i will need another hour of work
