hclmed
Jan 12, 2025Aspirant
Re: RBR50 - can't connect to primary network, only to guest
I have a slightly different but maybe similar condition where the hardwired LAN from the Orbi RBR50 base only appears as connected the guest SSID, which eliminates the value of separating them. I don...
CrimpOn
Jan 12, 2025Guru - Experienced User
hclmed wrote:
I have a slightly different but maybe similar condition where the hardwired LAN from the Orbi RBR50 base only appears as connected the guest SSID, which eliminates the value of separating them. I don't see a way to explicitly assign the SSID on the wired LAN. Is there a way to do that, and why would the wired LAN default to the guest SSID?
Thanks
Hard wired connections are not WiFi. They have no SSID. (not primary. not Guest. This is the definition of 'wired'.) Can you post a screen show showing this situation?
- hclmedJan 12, 2025AspirantI was hoping the ID was irrelevant, but it’s what shows up when hovering over the hardwired network icon in the taskbar, so it knows the SSID names. Is it safe to assume all hardwired connections are on the primary network?
- CrimpOnJan 12, 2025Guru - Experienced User
Yes, by definition all hardwired connections are on the primary network IP LAN subnet.
(I have no Apple computers....) Windows computers display a 'name' for the hard wired network when the user holds the mouse over the icon: It is not entirely clear (to me) how the computer discovers this 'name'.
