GeertCab
Aug 14, 2020Aspirant
RBR50 - Macbook Connection Issue
At home I have several devices connected to the Orbi network, including a SONOS system, several iPhones, Video doorbel,... I also have 2 macbooks and 2 windows laptops from work. When connecting...
Mstrbig
Aug 14, 2020Master
Is the Macbook set to obtain an IP address or is it set with a permanent IP address? It almost sounds like, since it is only the Macbook, that an IP reservation conflict may be causing it. Flush DNS and release/renew IP address on the Macbook.
GeertCab
Was set to auto receive an IP address.
But while I was looking further I learned the problem with the connection is with the MacBook (hard or software). I will start looking for a solution there. Seems te be an issue as both the MacBooks we have, endure this problem. Both same model. I just saw they had the same issue on other networks too (outside our home).
Thanks for the help!
