stefan_eb
Mar 07, 2019Tutor
RBR50 2.3.0.32 Firmware upgrade file incorrect?
Hi, Just downloaded RBS50-V2.3.0.32.img and RBR50-V2.3.0.32.img. The manual update of the Satellite worked fine. The RBR50 file however is not accepted by the router (This firmware file is incorrect!...
stefan_eb
Mar 07, 2019Tutor
OK, I found the solution. Before being able to upgrade the Orbi Router to 2.3.0.32 you have to install an intermediary update 2.2.1.212, this is only slightly higher that the latest release the router detects (2.2.1.210). After doing that it worked. The Satellite would upgrade directly however, without this intermediary step.
