japnmap's avatar
japnmap
RBR50 blue led light
Had a power outage last night, and today the blue led light on both my routers is off. Power is on, and everything seems to be working fine, but should that light be on at all times?
  • tagteam's avatar
    May 12, 2019
    When the ring LED is "Off", that indicates the router/satellite is working normally.
