note8guy
Sep 03, 2018Guide
RBR50 Bv2.1.4.16 mine just rebooted again!
I have had it with system. I am constantly getting disconnected from my note 8, maintaining a constant stream to my sonos wth spotify is a hit hit or miss and now BOTH the router and satiile just cr...
Streak2
Sep 03, 2018Master
There should be no problem handling your number of devices.
In the past when I have experienced the odd quirk after a firmware update, factory resetting the RBR50 and satellite did the trick.
It may be inconvenient for you to do this but may be worth a shot.
