Benekles
Nov 11, 2024Aspirant
RBR50 connection issues with Router only 100MBit
Dear users, I have a connection issue between Orbi RBR50 and the Router. After upgrading to Fiberglass (500 MBit) I have connected the RBR50 via a Cat7 cable to the Router (Telekom Speedport Smar...
- Nov 12, 2024
I am sure you will be laughing....
I placed an 1GB switch in between, so connected the CAT 7 cable to the switch and then with a CAT5e cable to the RBR50 - it connected with 1 Gbps!
Okay, assuming the CAT7 cable is not accepted by the Orbi, I connected it with a CAT 7 cable to the switch and now I expected again to have it connected at 100Mbps, but no, it is also connected with 1Gbps.
I do not have an answer to that strange behaviour. It seems as it just did not like directly been connected with the Router with that CAT7 cable. I just could not change the CAT 7 cable because it is in the wall.
Nevertheless, thank you very much FURRYe38 for the idea solving that issue.
By the way, I always forgot to say, that the Firmware is the newest, 2.7.5.4.
Nov 12, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
CAT6 UTP cable is recommended.
What is the connection rate speed shown on the RBRs web page under Advanced tab/Show Stats/WAN port?
What firmware version is loaded on the RBR and RBS?
Benekles
Nov 12, 2024Aspirant
Dear FURRYe38,
thanks for your reply. I understand that you see the problem in Double NAT and I understand the 3 options in eleminating Double NAT. Generally of course it was not my wish to create a double NAT, but it is due to the following reasons:
General setup of my System:
Modem is a Fiberglass Modem (without WIFI) from the german Telekom, only transfering Fiberglass into Ethernet data. This modem is connected in my house on the 1st level to the Speedhome which is setup as a Router creating a Wifi for the 1st level of the house. Additionally there is a Mesh Wifi 6-Repeater from Telekom installed in the living room on the 1st floor.
The Orbi RBR50 is of course setup as Access Point and connected via the CAT 7 cable through thick concrete/steel ceiling as the losses even through the backhaul are around 50%. On the second floor the Orbi spreads to 2 Satellites the data and PC´s are connected. Also it builds up an additional Wifi for the 2nd floor as the Wifi from 1st floor is too bad on the second floor.
As explaining this, if I want to keep the Wifi network on both 2 floors on a high level, I cannot avoid a double NAT situation, can I?
