Benekles
Nov 11, 2024Aspirant
RBR50 connection issues with Router only 100MBit
Dear users, I have a connection issue between Orbi RBR50 and the Router. After upgrading to Fiberglass (500 MBit) I have connected the RBR50 via a Cat7 cable to the Router (Telekom Speedport Smar...
- Nov 12, 2024
I am sure you will be laughing....
I placed an 1GB switch in between, so connected the CAT 7 cable to the switch and then with a CAT5e cable to the RBR50 - it connected with 1 Gbps!
Okay, assuming the CAT7 cable is not accepted by the Orbi, I connected it with a CAT 7 cable to the switch and now I expected again to have it connected at 100Mbps, but no, it is also connected with 1Gbps.
I do not have an answer to that strange behaviour. It seems as it just did not like directly been connected with the Router with that CAT7 cable. I just could not change the CAT 7 cable because it is in the wall.
Nevertheless, thank you very much FURRYe38 for the idea solving that issue.
By the way, I always forgot to say, that the Firmware is the newest, 2.7.5.4.
Nov 12, 2024Guru - Experienced User
So if you have a ONT or fiber modem with out the wifi, then be sure that the RBR is in router mode.
You may need to check with the ISP for there help and information to see if there is any additional requirements of connecting the RBR to the ONT or converter unit there.
Also check the connection rate at the RBR between the RBR and ONT or converter unit. The RBR will display this speed under advanced tab/Advanced/Show Stats/WAN port. Should read 1000Mpbs.
Benekles
Nov 12, 2024Aspirant
Hi FURRYe38,
thanks again for your very fast reply!!!
For clear details and maybe a better understanding, my setup of devices and cables is like this:
Fiber --> ONT Telekom --> CAT 5 UTP --> 2.5 GB/s --> Speedhome Smart 4 with WIFI "A" as Router --> CAT 7 S/FTP 568 B.2 --> 100MBit in WAN port / 1GBit in Ethernet port --> RBR50 with WIFI "B"
I thought due to the fact that the Speedhome Smart 4 Router acts as a Router including a (e.g. A named) Wifi I had to setup the RBR50 as AP not to ensure double "translation". I have a differently named Wifi setup 1st floor (A), the 2nd floor is setting up another WIFI (named "B") which is the same for alle 3 Orbis.
The above mentioned connection speeds are data from the Speedport Smart 4 Router. At the moment the Wifi built up from Orbi does not allow internet access. Only via LAN connected PC´s have Internet access. Also I cannot connect to the orbilogin page and check what Speed settings are available there. I have to factory reset the Orbi again to access it.
- FURRYe38Nov 12, 2024Guru - Experienced User
OK that helps.
So the RBR is in AP mode. And on the WAN port of the RBR it's only connecting at 100Mbps?- BeneklesNov 12, 2024Aspirant
Correct! That is the strange issue.
Would be curious, do you have a 1Gb non managed switch around that you could connect the RBR to to see if the WAN port will connect at 1000Mpbs?
Could temporarily connect any wired PC to the WAN port on the RBR and review the connection rate seen on the PCs ethernet adapter to see if the adapter is connected to the RBR WAN port at 1000Mbps. Disconnect after testing.
If a switch or PC shows 1000Mbps, then the issue may not be the RBR, rather what the RBR is connecting too.
