RDMSYS's avatar
RDMSYS
Star
Jun 05, 2020
RBR50 Firmware Update
I have a notification for new firmware (V2.5.1.16). However when I do the check, the router firmware is found but my Satellite stays at Please Wait A minute for 5 minutes then fails. I would like to ...
  • FURRYe38's avatar
    It usually should do everything, however maybe some times that doesn't work. So the alternative method of manually loading FW is available. Glad it worked for you. Please mark your thread as solved so others will know.
    Enjoy. :smileywink:
