Jaiter
Sep 23, 2022Aspirant
Rbr50 ipv6 6rd is broken
I'm trying to configure ipv6 using the 6rd method, but the rbr50 appears to be just dropping all ipv6 traffic and not allowing anything through. Interestingly I can ping it over ipv6 from a VPS on the...
CrimpOn
Sep 24, 2022Guru - Experienced User
(Sorry to be so slow......)
Wireshark capture on the PC Ethernet interface of ping -6 yale.edu:
Pretty clear that this RBR50 sends the IPv6 ping responses back to my PC.
Jaiter
Sep 24, 2022Aspirant
it must be a configuration thing with mine then, but theres so few options to adjust i just cant see what it can be
- FURRYe38Sep 24, 2022Guru - Experienced User
You might try loading Voxels FW on your 50 series and see if the IPv6 works better.
From understandings, NGs core IPv6 framework is out of date and hasn't been updated across all Orbi systems. This maybe causing problems.
