terrychau
Jul 16, 2021Aspirant
RBR50 Orbi app speed vs Device speed
My Orbi app shows a download speed of 50 mbps and with no other devices active, my device speed is only 22mbps even though I'm only 10 feet away from router. I've renewed my lease without any improve...
Jul 16, 2021Guru - Experienced User
what modem is it connected to?
what speeds do you get hardwired into the router?
terrychau
Modem gateway is 2wire 5268ac, it's wifi is off
I can't hardwire my ohone into it
- plemansJul 16, 2021Guru - Experienced User
terrychau wrote:Modem gateway is 2wire 5268ac, it's wifi is off
turning off the wifi doesn't disable its routing functions. Just its wifi.
it causes a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
