mediabiz
Dec 22, 2020Aspirant
RBR50 Orbi Router Cant connect to NBN
Hi, I bought a ORBI RBR50 system a couple of years ago to act as an access point as the WiFi from the iPrimus supplied NBN router was crap. At the time, I needed my VOIP landline, so I had to keep t...
CrimpOn
Dec 22, 2020Guru - Experienced User
mediabiz wrote:The web based setup went ahead but would not recognise the NBN fibre modem. I had made sure the ORBI was set to PPOe and supplied the correct username and password but cannot get the ORBI to see the NBN modem. Ethernet cable swaps, modem resets - nothing works.
Primus tech support told me there should be no issues as they claim they do not lock the service using MAC addresses or similar and I was free to use any router as long as it was NBN compatible.
This is the iPrimus network in Australia, correct?
I have searched for some sort of guide to "How to connect your router" without finding anything useful. (It doesn't help that iPrimus uses the term "modem" to refer to their combination modem/telephone/router/WiFi device.)
Did the original setup consist of two devices? (modem and router?)
Do you have one of these modems?
https://www.iprimus.com.au/setup?_ga=2.164566719.101044623.1608663724-966582565.1608663724
mediabiz
Dec 23, 2020Aspirant
Yes, that's correct, it's connected to iPrimus.
The router they supply is the Audiocodes MP264 - a widely used by several ISP's that is very cheap and has popped up as the culprit of many issues in various forums.
I have the NBN Co supplied fibre modem (the standard modem installed) plus the iPrimus Audiocodes router.
- CrimpOnDec 23, 2020Guru - Experienced User
mediabiz wrote:I have the NBN Co supplied fibre modem (the standard modem installed) plus the iPrimus Audiocodes router.
If the fiber modem has no product label, could you post a picture of it?
(use the Browse..." button in the lower left. Pictures posted "in-line" have to be approved by a forum moderator, which can take days.)
My son in North Carolina had fiber put in and the installer ran it inside the house all the way to their fiber box, which has an optical connector on it and an ethernet jack for his router. Not being familiar with iPrimus, I don't even know if the optical fiber plugs into this "Modem"... or what.
