RJSinMO
Dec 19, 2023Guide
RBR50 pulse white, then flash green and red and reboots endless
I have an RBR50 that about a week ago hung up. I powered off and on and now it just pulses white and then will do a quick flash of green and flash of red (on top ring). I factory reset it, and even...
RJSinMO
Dec 19, 2023Guide
I've confirmed a few things. If I factory reset it, and it comes up with the ORBI02 SSID, it is fine, and I can connect to it from my laptop. If I change it to something else, it is fine. But as soon as I change it to the SSIS that it has been for 5 years and all of my devices connect to, then the RBR50 crashes as soon as it comes up and goes into a booting loop. Most recent devices I can think I added are some cameras, so I'll try turning most devices off and adding them one at a time. However, when Orbi is down, I'm changing my T-Mobile router to that SSID and all the devices connect to it just fine. So, even if it is a particular device, this should NOT be crashing ORBI.
