StevenOrbi
Mar 23, 2022Tutor
Re: RBR50 randomly blocking devices and then responding extremely slowly
Recently seeing a similar problem where the Satellites are blocking devices that are setup in Access Control. Problem seems random and intermittent. I haven't disabled Access Control to see if the ...
Mar 23, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Circle enabled?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
