S_hui
Sep 06, 2023Aspirant
RBR50, RBS50
Hi , I have been using RBR50 router and couple of RBS50 satellites with ethernet backhaul for a while now. Recently I am noticing that the satellites will loose connection to router (it shows both sa...
Sep 09, 2023Guru - Experienced User
How many RBS are deployed?
What is the distance between the router and
satellite(s)? 30 feet or more is recommended in between RBR
and RBS
️ to begin with depending upon building materials when wirelessly or ethernet connected.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
What model# are the switches?
S_hui wrote:
My Setup | ISP ATT Fiber | Internet Fiber 1000↓/Motorola BGW210 | Wifi Router Disabled on Motorola modem-router | Switches TP-Link 5 port Gigabit | Orbi: RBR50, RBS50 |
S_hui
Sep 25, 2023Aspirant
Two satellites showing they are connected and network connection is good
- S_huiSep 25, 2023Aspirant
Satelites disconnected after taking the Macbook from wired connection and connecting to wifi
This problem is very erratic. Did not encounter the problem for a couple of weeks and it has returned this weekend 😞
- CrimpOnSep 25, 2023Guru - Experienced User
Thanks for taking the time to verify that the Orbi web interface Attached Devices matches the Orbi app in that when the MacBook Pro is connected to Orbi WiFi, both satellites lose their connection to the router.
Questions:
- Where is the MacBook Pro connected when wired?
Router? one of the satellites? one of the switches? - Does the satellite disconnection happen no matter where the MacBook Pro is connected?
- When connecting the MacBook Pro to Orbi WiFi, is the Ethernet cable unplugged before making the WiFi connection?
