alexpollard
Aug 07, 2020Aspirant
RBR50 Satellite keeps dropping connections
Connection has been rock solid since I bought it but recently my satellite connections keep dropping. I know because I lose connectivity to my NAS connected over ethernet. Rebooting the satellite eve...
Aug 07, 2020Guru - Experienced User
You might downgrade to v16 on the RBR and RBS. v32 saw some problems. NG pulled this version from there servers.
Factory rest the RBR and RBS and setup form scratch. Don't apply the backup config from file initially. See if the RBS fails again. If not, then try loading the backup config from file.
alexpollard
It took about 4 weeks before it dropped again since I updated the firmware so it’s really intermittent. Probably only happens once every 2 weeks or so but it’s really irritating.
Might downgrade again and see.
- MstrbigAug 07, 2020Master
I live in Florida. Storms have been causing power brownouts. Yesterday I had a satellite node on the 2nd floor drop out and never reconnect. This told me it was a rapid blip in the power, IE a fast brownout. I had to turn off the satellite, waited 30 seconds or so and turn it back on. It came right back up and connected. The only way I'm going to prevent this is to put the satellite on a UPS. I haven't because nothing else needs it in that location.
I'm mentioning this because this may be what's causing these disconnects. It doesn't take much power fluctuation to cause it.
- FURRYe38Aug 08, 2020Guru - Experienced User
I had my RBk50 online with a RBS50 and RBS20. Both saw no disconnections during a 14 day operational run. V16 seems to be very stable.
Possible some wifi interferences can cause some drops as well.
