Glenvis
Dec 25, 2019Star
RBR50 signal strength for Samsung QLED is low
My Orbi RBR50 is working just fine, laptop, Blink, & Lutron all working well. My remote is in my rec room about 13 feet from my Samsung QLED TV - straight across the room, nothing in the way - all un...
Jetdrive
Dec 25, 2019Luminary
What does your Samsung TV say about the signal strength? Usually TVs have a network section where you can setup and test the connection speed.
Glenvis
Dec 25, 2019Star
I checked the Network Status on the Samsung and it just shows connected - no chart or graph.
- CrimpOnDec 25, 2019Guru - Experienced User
When I briing up the Device Manager, it shows a list of connected devices. I tap on one, and it brings up a full page display with all sorts of details. The bottom item on my display is "Link Rate".
- GlenvisDec 25, 2019Star
Not sure where you are finding this info. In Windows 10, Device Manager, the Orbi doesn't show up.
In the Samsung TV, looking at Settings, Network, Network Status it only shows "Your TV is connected to the internet."
Sorry. I was talking about the Orbi "app". My Android app has a default page with a picture of the Orbi at the top and then a series of boxes:
Device Manager on the left - Security on the right
Internet Speed on the left - Parental controls on the right
Wi Analytics on the left - Network map on the right
WiFi settings on the left - Guest WiFi on the right
Traffic Meter on the left - Support on the right
Have to scroll down to find them all. It was this Device Manager I was looking at. Then, clicked on one of the devices.
