Glenvis
Dec 25, 2019Star
RBR50 signal strength for Samsung QLED is low
My Orbi RBR50 is working just fine, laptop, Blink, & Lutron all working well. My remote is in my rec room about 13 feet from my Samsung QLED TV - straight across the room, nothing in the way - all un...
CrimpOn
Dec 25, 2019Guru - Experienced User
Glenvis wrote:Yet, according to the Orbi iPhone app, the signal strength is only one or two bars on the display. Not sure if this is accurate or if I should be doing something to increase the signal strength.
(I have no Apple, but) My Android Orbi "app" shows the "Connect Rate" for each device. At what rate is the Samsung TV connected?
Glenvis
Dec 25, 2019Star
The Samsung TV shows it is connected at 5GHz on the iPhone app.
