cortex
Jan 11, 2021Aspirant
RBR50 spontaneously bricked itself this morning - factory reset has no effect - what are my options?
I woke up to find I had no wifi and no internet. My two satellites had solid magenta rings. The router had power but no illuminated ring. I I tried to connect directly to the router via ethernet I co...
Jan 14, 2021Guru - Experienced User
How many times did you tri the reset before the LED turn the right color?
What version of FW were you able to load?
Glad you got it working.
growly wrote:I had a similar problem a few days before you. I logged into the web interface to check something but strangely it wouldn't display the contents of some frames - I would get a server error (I can't remember which HTTP code). That was very weird (NETGEAR: it was broken) so I rebooted the device. It then bricked itself; the power LED flashed RED which, according to the manual, means "corrupt firmware". So I did the factory reset a few times until it blinked the right colour.
I used my phone to download another firmware image and TFTP'd that to the device over an ethernet cable from my laptop. I had to set a static IP in 192.168.1.0/24, but the router responded to 192.168.1.1 and consumed the TFTP image. I then left it for a while. Nothing. I tried again. This time it came up and I could log in.
growly
Jan 14, 2021Tutor
This happened at 3 am so my memory isn't the best, but after 3 or 4 factory resets all resulting in the "corrupt firmware" state (blinking red), I acquired and managed to TFTP the firmware across. It then failed to boot, but the error had changed from blinking red to blinking amber. Then I did a reset another couple of times and TFTP'd the image again until it seemed to do the right thing.
/edit: My impression was that the TFTP server was up always in the blinking-red state, but in the blinking-amber state it was only up for a few seconds before boot proceeded at normal.
The firmware version I used to get it "working" was 2.7.2.102.
